W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: hjhofman on July 05, 2017, 14:08:26
Title: 280 SE/NV engine
Post by: hjhofman on July 05, 2017, 14:08:26
Good day,
I have a 1964 230 SL  where the engine has been replaced with a 280SE/NV from probably a W111.
Can anyone tell me what the background of this engine type is and why it has a lower compression?
regards,
herbert
Title: Re: 280 SE/NV engine
Post by: mbzse on July 05, 2017, 18:34:28
Quote from: hjhofman
.../... the engine has been replaced with a 280SE/NV .../...Can anyone tell me what the background of this engine type
The engine type is indicated by the number after "130" on the engine ID plate and/or punched into the engine block. In your case perhaps 130.981 or 130.984(?)
Compression on such a low compression M130 NV is 8 to 10 kg/cm2 at running temp; minimum is 6,5 kg/cm2.      Nominal compression is 7,8:1.
 A normal M130.983 engine as mounted in a 280SL /8 Pagoda has 10-12 kg/cm2 at running temp; min is 8,5 kg/cm2.   Nominal compression is 9,5:1.
A lower compression engine can be run on lower grade fuel
Post by: 450sl on July 05, 2017, 19:20:24
280SE/NV   is the designation of the head, the actual enginenumber is stamped in the casting  of your engineblock.
Post by: hjhofman on July 08, 2017, 12:04:50
Gents thanks for responding.
Hans you are right the engine number is probably  130.984.10.000478 ( as far as i can decipher it)
Can you confirm from which model the  engine comes from?
Was the engine developed for a specific region  as it can handle lower grade fuel ? And if that is the case  for what reason?
regards,
herbert
Post by: Cees Klumper on July 08, 2017, 17:28:44
From memory it's from a 280 sedan, the data should be in the tech manual. I suppose you could replace the head with a standard, higher compression one if you want to go that route.
