W113 Pagoda SL Group => General Discussion => Topic started by: Taleb on June 17, 2017, 18:04:15
Title: purchasing gearbox
Post by: Taleb on June 17, 2017, 18:04:15
hello all ,
i already have 280sl pagoda 1968 and only required the automatic gearbox for it , please advice if anyone knows where to purchase it ,
thanks
Title: Re: purchasing gearbox
Post by: merrill on June 19, 2017, 12:30:50
you can try calling mark at
http://www.mercedesdismantlers.com/
Phone: (818) 782 2300
Post by: Taleb on June 19, 2017, 15:10:40
hi matt ,
I already contact them , they don't have at the moment ... thanks anyway
Post by: RAY on June 19, 2017, 18:59:42
Have a look in the Technical Manual under suppliers.
Post by: merrill on June 19, 2017, 19:50:53
Gernold at sl tech
adsit company.
Adsit as a last resort
Post by: cabrioletturbo on June 20, 2017, 01:04:39
Have one off 230SL, should be the same?
Contact via PM for details.
Post by: Jonny B on June 20, 2017, 16:00:48
One difference on the automatic transmission is the type of torque converter. The 230 and 250 had an aluminum converter that had a bit of a tendency to leak at the rivet joints. From what my mechanic told me, the leaks are extremely difficult (close to impossible) to repair. On the rebuild of my transmission he installed a later type, steel with a welded joint (at the input shaft).
I know there are also differences with the bolt pattern on the converter itself. Mine required six bolts. These are on the converter itself, and are in groups of two spaced around the edge of the converter (there are two bolts at what would be the points of an equilateral triangle).
Post by: Taleb on June 20, 2017, 23:24:19
Thanks a lot Jonny for all this information and I will keep it in mind because someone just offered me 250sl gearbox .
Taleb
