W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Thierry du Laos on January 30, 2017, 07:19:46
I am trying to adjust the engine.
When idle is ok, if apply the brake: the RPM increase! Which is a problem when braking!!!!!
I though the engine was to rich, but if i increase air with the idle air screw, then it will stop or won't stand the gear shifting!!!!
Quite tricky between richness, gear auto, idle actuator and brake vacum????
Or do I miss something!!!!
I am going round and round....
If the RPMs increase when you apply the break, you have a vacuum leak in your brake booster. It's a pretty common problem. The booster will need to be rebuilt.
First check brake booster leak
Thanks, I will.
Correct, its the membrane!
(http://img11.hostingpics.net/thumbs/mini_362054IMG4598.jpg) (http://www.hostingpics.net/viewer.php?id=362054IMG4598.jpg)
(http://img11.hostingpics.net/thumbs/mini_171725IMG4600.jpg) (http://www.hostingpics.net/viewer.php?id=171725IMG4600.jpg)
(http://img11.hostingpics.net/thumbs/mini_818728IMG4604.jpg) (http://www.hostingpics.net/viewer.php?id=818728IMG4604.jpg)
(http://img11.hostingpics.net/thumbs/mini_685389IMG4606.jpg) (http://www.hostingpics.net/viewer.php?id=685389IMG4606.jpg)
(http://img11.hostingpics.net/thumbs/mini_218093IMG4605.jpg) (http://www.hostingpics.net/viewer.php?id=218093IMG4605.jpg)
Now, new step is where can I find these membranes?
Finally I have got the 2 two brand new membranes and will re-assembly the brake booster.
(http://img4.hostingpics.net/thumbs/mini_139502IMG4875.jpg) (http://www.hostingpics.net/viewer.php?id=139502IMG4875.jpg)
And next is the new soft top!
I can't wait any more to cruise with the car!!!!
Good for you Thierry, c'est bien fait. Good luck with the repairs, keep us posted.
Hi Thierry
A good result, from where did you find the membranes
Thank you
Quite difficult to find the membranes. Got them form a member of the forum.....
Now the engine is fine and the brakes too.
I just need to finish the soft top to go and cruise!
Well done, Thierry,
Chris
Thanks Chris....
Would "the member on the forum" please reveal himself!
+1
