W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: col320ce on November 26, 2016, 15:25:51
Title: Windows washer water pump mounting
Post by: col320ce on November 26, 2016, 15:25:51
Should the windows washer water pump be mounted vertically or horizontally.  Mine is vertical and works when it's primed but if I try to use it the following day it doesn't seem to move the water as the 'gears' are spining in air.
I assume this is a positional thing.
Any pictures of it in a RHD 230SL as I'm not sure where it goes if it's horizontal.
Thanks for any help...
Title: Re: Windows washer water pump mounting
Post by: cfm65@me.com on November 26, 2016, 16:06:29
Hi Col,
The washer pump is mounted horizontally.
If you look under the General Discussion section, about 3 posts down is a post re Hemmels restorations. They have a nice picture of the engine bay of a LHD which should give you an idea. Mine is unfortunately also LH. However, someone is bound to send you a picture if you cant figure it out.
Chris
Post by: Tyler S on November 26, 2016, 18:55:52
Either way it is mounted, air can get into the system if the washer bottle level is lower than the pump. A check valve can be added to the end of the washer hose in the bottle to keep it primed.
Post by: Garry on November 26, 2016, 21:33:04
This is mine on a ’65 230SL RHD
Post by: col320ce on November 26, 2016, 23:11:21
Awesome info!
I'll re mount mine and try to source a check valve.
Post by: col320ce on November 27, 2016, 05:42:40
All mounted horizontally and working well.  I've ordered a 4mm  check valve so hopefully this makes it work instantly each time...
Thanks as always...
