W113 Pagoda SL Group => General Discussion => Topic started by: srisant on November 02, 2016, 13:56:09
Hi, I have to replace my cylinder head, wondering if 220SE cylinder head will work perfectly with 230SL head? If not what will be alternative?
250SE/SL is your only other choice.
Yes, Dan is correct. The 220SE head has no provisions for injectors. The 220SE has injectors mounted on the intake manifold.
If I use 250 head is it going to impact engine performance or it will be the same?
It might even be a bit better due to slightly higher compression ratio and larger intake valves of the 250.
