W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: swood1 on October 22, 2016, 12:47:32
Title: 250 SL seat adjustment knob removal.
Post by: swood1 on October 22, 2016, 12:47:32
Hi all,
Can anyone advise on how to remove the black seat adjustment knob as per photo attached?
Steven
Title: Re: 250 SL seat adjustment knob removal.
Post by: cfm65@me.com on October 22, 2016, 13:47:56
Hi Steven,
There is a hole in the back to pop the cover.  The wheel is then held in position by a large phillips screw if I remember correctly.  I have rounded the sharp end of an old phillips screw driver, then gave it a 90* bend about an inch or so from the rounded end. Find the hole in the back, I think there might be two, stick the 90 degree bend into the hole and pop the cover off.
Chris
Post by: Pinder on October 22, 2016, 13:52:14
you can also use an allen key to get behind the knob and push through the hole. I think there are two holes so you can push it out evenly.
Post by: swood1 on October 22, 2016, 14:14:04
Thanks guys.
Shall give it a go.
Post by: swood1 on October 23, 2016, 18:55:19
All sorted now.  Tapped it off with an old screwdriver with a broken tip.
Cheers
Steve
