W113 Pagoda SL Group => Electrical and Instruments => Topic started by: col320ce on October 11, 2016, 00:38:07
I'm pretty sure my thermo time switch is not working
On the bench I get 92.5 Ohms through G (and earth) and an open circuit on W, both at high and low temperatures (out of the fridge and in glass of 60 deg C water).
This is without putting 12v onto the G terminal and letting it warm up. Is there another bench test I can do or is this enough to tell that it is bad?
It does not look serviceable ...
I stuffed the in car test up ... so I'll need to put it back in to check this again.
The marking are:
max 120
36/2/10
+5 C
+/- 3 C
4.76
-20 C
/12 sec
Thanks for any help ...
The TTS testing procedures are listed here: https://www.sl113.org/wiki/Engine/ThermoTimeSwitch
Thanks .... it's toast
