W113 Pagoda SL Group => General Discussion => Topic started by: steven harris on October 06, 2016, 14:42:05
Title: 250 SL 5 Speed
Post by: steven harris on October 06, 2016, 14:42:05
What information does this include? Should be 67 250 SL Silver, Blue Tex, A/C, Power Steering, 5 Speed. Any help greatly appreciated
Title: Re: 250 SL 5 Speed
Post by: wjsvb ✝︎ on October 06, 2016, 16:34:10
Suggest that you cover the key codes!
Post by: steven harris on October 06, 2016, 17:21:14
Thank you. I didn't realize they were in the sheet. I might just re-key it (saving the originals). Just amended the posting and (I think) blurred the key codes.
Post by: 66andBlue on October 07, 2016, 00:33:25
You can decode all the fields using the information provided in the Technical Manual: http://www.sl113.org/wiki/DataCard/DataCards
Post by: steven harris on October 07, 2016, 08:29:12
Thank you for the link. Most helpful!
Post by: 114015 on October 10, 2016, 19:49:05
Wow ....!   :o
Hello Steven,
So your car has option code 230 which refers to the ZF 5-speed. However, that option code always came with code 232, which means 4.08 rear end. That one is clearly missing with your car.
Instead, the "Hinterachsen-Nr." clearly implies that you have got a 3.92 rear end.
Very, very uncommon.
But you are absolutely sure to have the ZF 5-speed? Yes?
Post by: steven harris on October 12, 2016, 14:19:31
The car has a five speed that was ordered from the NY Mercedes of North America dealer. Three of the best SL113 experts in the US all believe it is original to the car and all the (extensive) paperwork supports that. I have no idea about the rear end. It drives beautifully. In two weeks, I will be driving it in California and will post the RPM / speed ratios.
