W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: swood1 on August 25, 2016, 14:34:43
Title: PAS Box - query on small rubber seal
Post by: swood1 on August 25, 2016, 14:34:43
Hi all,
I have rebuilt my PAS box but I have one small rubber seal left over.  On looking at the exploded views the only area I could find where this seal could possibly go is shown in the attached pic.  But when I take these two parts apart there is no recess to fit this seal into. Could my box be an older unit without the recess for such a seal?  It's a 250SL.
I could add a recess if need be to the casting.
Steven.
Title: Re: PAS Box - query on small rubber seal
Post by: tel76 on August 27, 2016, 13:17:34
There should be a recess machined into the housing that is bolted (four bolts) to main steering box housing.
Post by: swood1 on August 30, 2016, 22:22:45
Thanks for feedback,
Sorry just noticed your response.  I dont get email reminders on replies to posts (not sure if it can be activated?).
I shall have another look at the casting/assembly.  Although if there is no recess and I need to add one I do hope there is a way of removing the end casting without disassembly of the worm and ball bearings :/
Steven
Post by: swood1 on September 06, 2016, 06:51:20
Sorted it and didnt have to strip it right down either.  I picked around the hole with a scriber and low and behold a seal popped out.  Not easy to see, it was that flat it just looked like part of the casting.
Alot more confident with the power steering box now. It's a project in itself, impressive engineering.
Steven
