W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: Shvegel on June 22, 2016, 00:14:27
After spending a couple hours trying to strip the factory wax undercoating off the bottom of my gas tank I am wondering if anyone has figured out a better way? I used Lacquer thinner, Acetone and strong degreasers with little success. I finally ended up hitting it with a wire wheel mounted to a grinder. Not fun.
Dry ice works wonders on old coatings.
get one of those stripping discs from harbour freight. they look like a sponge. they wear as they strip paint and pretty much anything. you can probably do the tank in 30 mins tops. wear a full face mask.
its called a 4-1/2 in. Polycarbide Abrasive Wheel. great for paint removal in seconds. i can do a whole roof on a car in about 30 mins. its around 6 bucks at HF.
I used the PAW (polycarbide abrasive wheel) for lots of nasty jobs like that and it works like a dream. Cheap too. The grindings go everywhere.
Thanks all. Luckily I don't have too much left just the front crossmember and suspension. Spraying a little wax on the bottom of a car to keep it from rusting seems pretty futile but 45 years later it is still there.
