W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: mbazinet on June 19, 2016, 05:51:51
Title: Need a New Radiator for my 1966 230SL any good suppliers ?
Post by: mbazinet on June 19, 2016, 05:51:51
Hi , new member  does anyone know where i can purchase a new radiator for my 1966 230SL ?
any help very much appreciated
Title: Re: Need a New Radiator for my 1966 230SL any good suppliers ?
Post by: Ron500E on June 19, 2016, 07:49:59
I had my old one re-cored. Cost around $350.00 or so in Chicago.
Ron
Post by: badali on June 19, 2016, 13:21:17
I just had mine re cored also at $400.  I called around and found a used one that was supposedly reconditioned and they wanted $1495.  By the way it was ADSIT that had the used radiator.  Their on line price was $1345 and when I called the price was $1495.  I had my original re-cored instead.  If you do find a used one you will probably have to get it re-cored anyway.  Make sure it is for the correct transmission in your car.  The automatic has a trans cooler.
Post by: perry113 on June 19, 2016, 15:26:46
I just had my radiator recored for my 1966 230SL with the correct radiator core for $500.00. That's the only way to go.
Post by: mbazinet on June 19, 2016, 19:31:59
Thanks very much guys looks like mine has been repaired and recored a few times   probably should look to get a new "donor" core to work with    I appreciate all the help !
Post by: kampala on June 20, 2016, 04:54:01
Especially since you are in Maine you should visit Gernold.   He's one of the experts on these cars and has a particularly good reputation specifically for radiators.   You will read a lot more about radiators and Gernold on this forum.
Here is Gernold's website link to the radiators he supplies:  http://www.sltechw113.com/parts.html
Post by: Benz Dr. on June 20, 2016, 12:04:19
As long as your upper and lower tanks are OK you can get it cored as many times as you like. Is there something wrong with yours?
Post by: mdsalemi on June 20, 2016, 13:28:55
I purchased a recored unit from Gernold on exchange in 2011.
Typically, when you go to a "local" radiator shop in your area, where ever that may be, the shop will use/order standardized radiator cores they purchase and solder the unit back together. That's why sometimes when you see a recored radiator on an older or import car [in the US] it doesn't always look correct.
What Gernold told me is that he found a place, I think it was in Maine, where the firm had the equipment to actually manufacture the cores--you know, bend the fins, create the tubes, etc. So, Gernold came up with the sizing and capacity specs and has the cores made for him specifically for the Pagoda radiators.
My recored unit from Gernold worked perfectly from the moment it was installed. Surely this isn't the only workable solution but those who know Gernold know he has extremely high standards.
Post by: Mechudo62 on June 23, 2016, 23:05:36
The Mercedes Benz Classic Center in Irvine, Ca. last February quoted me $945.00 dollars (with MBCoA discount included) for a brand spanking new radiator for my 1970 280SL... If they still have them available I would go with a factory unit for added peace of mind...
Post by: mbazinet on July 14, 2016, 01:51:22
Mine has been recored a few times while the car was in Florida  it looks like the tanks have had  some rough treatment  they are dented and just don't instill a Proper quality with me.
Yes I need down to visit  Gernald  he did return my call and I am eager to meet him from what I have seen he is very well regarded. He's not to far from Bangor.
Post by: 66andBlue on July 14, 2016, 05:39:04
The radiator for a manual 230SL is also available from the parts manufacturer in Poland:
http://www.sl113.org/wiki/Suppliers/Warsaw
Scan down to the bottom of the list "nr B037": http://www.retroteile.pl/index.php?option=com_content&view=article&id=12&Itemid=9&lang=pl
Post by: UJJ on July 14, 2016, 11:14:23
Agree with Michael, Gernold is the best way to go (not only in radiators)
Urban
