W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: erickmarciano on March 31, 2016, 16:27:58
Title: Ball stud sealer? What to use?
Post by: erickmarciano on March 31, 2016, 16:27:58
Hi guys
Have to reinstall all the ball studs on the head? What is the bedt choise sealer
Red locktite?
Title: Re: Ball stud sealer? What to use?
Post by: wwheeler on March 31, 2016, 18:20:49
Something like this is another option http://www.permatex.com/products-2/product-categories/thread-compounds/thread-sealants/permatex-thread-sealant-with-ptfe-detail
The temperature rating is key as these are near exhaust gases. I use this for many coolant applications with great results and is non-hardening. Will also provide a barrier for corrosion between the steel and aluminum.
Post by: Benz Dr. on March 31, 2016, 20:45:05
Don't use anything that would keep you from being able to remove the ball studs. I also use Permatex thread sealant which will work just fine for this application.
Post by: ja17 on April 01, 2016, 04:32:42
Yes, I agree on the Permatex!
Post by: Raymond on April 04, 2016, 14:52:13
Locktite would be a bad idea.  Someone did that or something like it, to the ball stud over the 6 spark plug before I got the car and the threads in the aluminum head were destroyed when it was removed.  I had to drill it out and put in a thread insert.  Definitely use the permatex thread sealer.  Otherwise it WILL leak.
Post by: erickmarciano on April 05, 2016, 16:53:48
omg these were so hard to put back on  , put them in dry ice or freezer before installing
thanks
