W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Autobob on February 25, 2016, 20:28:34
Attached photo at red arrow, we have a threaded hole but do not know what goes there please advise, it is next to cylinder #6.
Arrgg, It would have been so much simpler if this car had been assembled when it arrived. So many missing parts...
Thank you, Bob
I think that is the port for a Thermo Time Switch if your car is a late 280sl. Earlier cars had this switch on a pod closer to spark plugs 2 & 3. Later cars have this switch next to spark plug 6. Sometimes, this port is used for a cooling by-pass modification and in such cases the TTS is moved into the bypass line.
Thank you that helped, yes this is late model 1971, I found it in technical forum part 001 545 92 24. Looks like NLA from Benz, Joe or Alfred would you have one of these?
Thermo time switch? That should be readily available.
OK then part number in technical may be superseded, will check that out. Thanks, Bob
Sorry, don't have one.
@Benz DR, just heard back from MB dealer, TTS discontinued and no superseded number. Rats.
Here is one at Auth Classics. Very Pricey
http://www.authenticclassics.com/Mercedes-Thermo-Time-Switch-fits-230SL-250SL-p/auth-004360.htm
Or you can use this one with a slight harness modification. The rubber boot will hide the connection.
http://www.authenticclassics.com/Mercedes-Thermo-Time-Switch-230SL-250SL-280SL-p/auth-006760.htm
Wow, crazy prices on these!
Another disappearing part that will go way up in price just like the fuel pumps last year.
here you find some info: www.sl113.org/wiki/Engine/ThermoTimeSwitch.
...WRe
