W113 Pagoda SL Group => General Discussion => Topic started by: Malc on October 22, 2004, 08:36:59
Title: Good News! - Data Card
Post by: Malc on October 22, 2004, 08:36:59
Got a copy of my data card from the dealer in Aberdeen! Yiphee :)
Now I have rummaged through all the data bases I could find including "our own"  Please note it's a rather fuzzy photcopy so I am starting at the top and then reading each major line
Entries with a  :?:  could somebody tell me what it means
1st number refers to the box number on the card
4 - Type - 230SL (Humm on the right track ;) )
line 1
Schid??-Nr : 3022  :?:
Chassis Number - 008604 OK
Prod Nr: 00247  :?:  (Yearly production number?)
18 - Build Number 06572  :?: (actual number built to date?)
Bau.... :113042 10  :?:
...ge Nr.: -2219301  :?:
10 -  paint code: first box 050 second box 050  :?:  050 white?
17 -  upholstery: 210  :?:  word is very fuzzy
40 - 1, assume this means trimmed with leather  :?:
41 - 6, Hardtop mounted
line 2
42 through 59 blank
60 - 0, chrome strips on hard top (true  :) )
after box 68 there is a box for 4 three digit numbers, I can't make out the title but the left number is 720 rest blank
last box on line unreadable title, blank
line 3
5 - chassis number ok  :)
11 - engine number ok 127981-10-007458
"Zuhassungsdatum" - blank
"Ol......" - blank
line 4
6 - transmisson number - ok
12 - front axle number left  - ok
19 - front axle number right - ok
line 5
7 - rear axle number - ok
13 - tyres - ok - 6J.14H I think this actually should be translated as WHEELS or rims
20 - tyres - 185.14 Phau (a with umlaut)
line 6
8 - steering box number - ok
14 - ignition key number - ok
21 - tank, door, trunk key number - wierd symbol here suspect means same as ignition key number  :?:
line 7
9 - battery - Varta (For you purists, only teasing[:p])
15 - Headlights - Bosch
22 - windscreen wipers - blank (Assume this is the make rather than if they are fitted!!!)
line 8
Ober....tag - Order date  :?:  1 march 1965
14 - Koffer and glove box key, whats Koffer :?:
last box is blank but has a capital "R" in it
Whew
Malc
Title: Re: Good News! - Data Card
Post by: n/a on October 22, 2004, 08:54:47
14. I think koffer means trunk.
Post by: Malc on October 22, 2004, 08:57:01
Thanks!
Wierd seems as thats reported in box 21 I guess this is a generic data card for various models
Malc
Post by: jeffc280sl on October 22, 2004, 09:48:01
I've done what i can by using my 1970 data card.  Hope it helps
4 - Type - 230SL (Humm on the right track)
line 1
Schid??-Nr : 3022
Schicht-Nr.= Class No
Prod Nr: 00247  (Yearly production number?)
18 - Build Number 06572 (actual number built to date?)
Bau.... :113042 10
6 Fahrgestell-Nr.=Chassis No
...ge Nr.: -2219301
Auftrage-Nr.=Order No
10 - paint code: first box 050 second box 050  050 white?
17 - upholstery: 210  word is very fuzzy
the word is Ausstattung=Interior Decor  2xx=Leather
40 - 1 means single seat
line 2
42 through 59 blank
60 - 0, chrome strips on hard top (true )
wenig gewunscht  720 is the color of your folding top
Hinweis=Special Note (is the last box title)
line 3
5 Aufbau-Nr.=Build Number
"Ol......" - blank
Olmarke
line 4
line 5
line 6
line 7
9 - battery - Varta (For you purists, only teasing)
line 8
Ober....tag - Order date  1 march 1965
Post by: Klaus on October 22, 2004, 14:29:26
Malc, you still have the early type data card (the layout changed pretty often). Your data card is explained on this website, there for a 190SL:
http://www.mbspares.com.au/default.asp?d=18018&p=18013
Klaus
1969 280 SL
Post by: rwmastel on October 26, 2004, 12:43:43
Now I have rummaged through all the data bases I could find including "our own"  Please note it's a rather fuzzy photcopy so I am starting at the top and then reading each major line.
Malc,
You have the same format Data Card as I do.  Do you know where on your car to find your axle numbers, steering number, etc.?  I can help there.
I think built into the number "2219301" there is a code that determines the country of destination.  That would be interesting to know.
The "050" code is your paint code (body/hardtop).
The "40/1" code is your bucket seats.
The "210" code is your leather color.
The "720" code is your soft top color.
For the tires, the "Phau (a with umlaut)" is probably Pheo for Pheonix, the tire brand name.
Post by: Klaus on October 27, 2004, 18:50:00
-2219301
actually, the order no. should have eight digits. In your case, probably the first digit (where you show a dash) should be a 4. If this is correct, then the next three digits, 221, identify the ordering MB dealer as Koeln / Cologne, Germany.
Klaus
1969 280 SL
Post by: Malc on October 28, 2004, 02:45:09
Originally posted by Klaus
-2219301
Klaus
1969 280 SL
This is starting to make me believe in Karma. I have known somebody who lives in Koln since 1974 when I went on a school exchange trip!!!
THey live, excuse the spelling on SiebenGeberstallee and there is an MB dealer just down the road...
THanks to all for your help, wonderful!
Malc 8)
Post by: rwmastel on October 28, 2004, 20:05:54
Aren't Data Cards great???  :D
