W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: relbhcb on January 05, 2016, 16:43:49
I can't get my 230SL's engine to start - after 2-3 years of never letting me down :( .
- If I do not touch the throttle pedal and turn the key (after having let the fuel pump pressurise the system for ~10 seconds) then the engine fires for a couple of seconds at low RPM, but then dies - tick over is not self sustaining, and even if I "tickle" the pedal to keep it going the engine cuts out anyway.
- Alternatively, if I press the throttle fully to the floor and turn the key then it roars in to life (maybe 2,500 RPM) :o , but as soon as I try to reduce the RPM the engine dies.
- If I do either of these more than two or three times I then have to leave it for ~10 minutes before it will fire again.
I had thought that the automatic choke required you to not touch the throttle during start, but the full-to-the-floor method was given to me to use if all else failed (& it did get me started last weekend).
Any suggestions as to what I can look at? The battery is fine, and the fuel tank is half full with reasonably fresh petrol. The electronic fuel pump sounds normal.
TIA
Your engine isn't getting enough fuel which could be any number of problems. I would look at ignition first and then fuel pressure.
Ditto, on Dan's reply.
Thanks both; I have asked my independent MB specialist to come over on Friday to have a look at it - fuel issues (injection) are beyond me I'm afraid. :-[
You need a good strong spark which you can check at the coil wire. Fuel volume is generally a sign of good fuel pressure. Both of these tests are on this site.
Any updates on the car?
Probably the warm up regulator on the IP. It could be stuck in the fully warmed position.
