W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Autobob on December 01, 2015, 21:21:00
Continuing on my 1971 280sl project, I am missing the engine oil dipstick tube does anyone have a spare to sell? I have checked with MB Classic and have ordered a new stick but they have no tubes or tube to pan seals. Thank you, Bob
Thought I did but no luck. I have the early 280 stick and tube with the long handle on the stick.
The "Middle" on Joe's post: http://www.sl113.org/forums/index.php?topic=23304.0
If you are not worried about originality I am sure it would work just fine.
Do you know how long it is. I may have it, just want to be sure of the length.
Mine is 16" from the bump at the oil pan end to the top. I'll shoot a pic later and post it.
Mine is only 7 1/2".
Sorry.
View pic.......................
I couldn't get a good shot of the later dipstick tube but it is about 16" from top to the bump where it meets the upper oil pan and it has about a 25 degree bend in the middle. Again the mid year dipstick and tube should work if you get into a bind but it isn't "correct" for your car. I'll send you the mid year tube and stick as a freebie if it helps you out...if I can get it out of the upper oil pan.
Sorry.
Most guys never complain about that.
Good humor, Dan. Made the day.
First I must say I am embarrassed that I have not noticed the replies to my thread. I thought I would receive an email when someone replied and hence thought no one did. No doubt there is a setting I need to check when making a post.
Shvegel that would have been great as originality is not this cars forte. This 71’ 280sl was a barn find mix of SL and SE engine parts with missing parts. On the dipstick I ended up with a new long tube and a new middle short dipstick as in Joe’s photo. I have on the way a new long dipstick so hopefully it will be resolved. Again everyone that replied, Shvegel, Cabrioletturbo, ja17 Joe, Benz DR, thank you, I will improve. Bob
Yes... underneath your post click on the '+' in front of Attachments and other options
Select "Notify of replies"
Got it, thanks. Bob
