W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: SilverSpear on October 26, 2015, 16:54:21
Title: Camshaft Bearings
Post by: SilverSpear on October 26, 2015, 16:54:21
Hey guys,
Anyone knows the part number of the early 250SL Camshaft Bearings?
I have the number related to the set of 4 but not the individual units by themselves.
The camshaft is the 8601, and assuming it is brand new.
Appreciate your quick response guys.
Danny
Title: Re: Camshaft Bearings
Post by: stickandrudderman on October 28, 2015, 17:29:03
You cannot interchange individual cam bearings; they are line-bored as a set.
Post by: Benz Dr. on October 28, 2015, 20:44:14
Maybe you shouldn't, but you can, as I have had to do a couple of times. New cam bearings are precision made but as they wear you can sometimes sneak a used one in to replace a broken or damaged one. As long as the cam will turn freely after everything is torqued down you should be OK.
I had an engine in a while back ( 190SL ) and both end bearings were broken off at their flanges. Closer inspection showed where a previous shop had hooked chains under the head bolts and used that to lift engine in and out of the engine bay! This clever approach broke the bearings off about an inch above the top of the head. I replaced the cam bearings with good used ones and it still runs fine several years later.
Post by: ronaldwardmd on November 13, 2015, 21:54:56
No. However do you know the symptoms of camshaft problems and fixes?
