W113 Pagoda SL Group => Electrical and Instruments => Topic started by: Madmerc on October 11, 2015, 21:56:08
Title: wiring og the regulator
Post by: Madmerc on October 11, 2015, 21:56:08
hi all I have a 1964 230 sl which I think is a regulator its located on the right side of engine bay there are 4 wires going to it there is a red and blue together a single black and a single brown there is also a brown wire which im sure goes to the body. on the regulator there are markings    df   d- d+ could any one kindley show me which colour wires goes to which point on the regulator  thank you
Title: Re: wiring og the regulator
Post by: Garry on October 12, 2015, 01:27:56
You need access to the coloured wiring diagram in the Tech Manual but for that you need to be a Full Member. Full Membership does have its privliages ;) ;)
From your friendly Membwrship Administrator
Post by: Madmerc on October 12, 2015, 06:36:50
thanks garyu ill do that now didn't relize it cheers
Post by: Garry on October 12, 2015, 07:49:25
You should have full access once a Full Member to the coloured Wiring Diagrams.
Title: Re: wiring of the regulator
Post by: Madmerc on October 12, 2015, 08:03:05
yes thanks gary I have sorted that problem out with the colour electrical was a great help even got the alternator wired up as well but I just cant seem to get the coil to the distributer right I think I have wired it up but no spark at the points
