W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: rjfurlan on August 05, 2015, 14:17:51
Title: Source for manual trans sealing ring
Post by: rjfurlan on August 05, 2015, 14:17:51
I am changing the fluid in my manual trans and need the sealing ring for the drain plug, N 00760302410.
Anyone know of a source  and size for these. Are they just standard aluminum seal rings I can buy at the aoto parts store?
Title: Re: Source for manual trans sealing ring
Post by: ctaylor738 on August 06, 2015, 06:13:40
With the PN you should be able to get it from a dealer.  You can also take it to a good auto parts store and try to match it.  But if you are a true parts geek, you can look up the spec here:
http://www.sl113.org/wiki/uploads/Restricted/Schluessel_Liste_Nr_7.pdf
