W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Steven A on July 22, 2015, 23:11:51
Dear All,
Firstly, a thanks for the excellent advise the Pagoda Technical Manual provides, and the advice in the forums - appreciated!
Appreciate any guidance re obtaining parts for the distributor vacuum advance on an early 230SL (ref http://www.sl113.org/wiki/Electrical/Distributor#Advance).
The distributor is model VJUR6 BR 49T (photo of advance and distributor model plate as attached). I am not getting full ignition advance, (so is on the safe side) and want to service/replace the vacuum advance diaphragm/pull rod mechanism part or ideally the whole vacuum advance unit - there does not appear be a separate Bosch or Mercedes part # for this.
Thank you,
Steven
Contact the Benz Doctor he will fully service your distributer or supply parts if required.
Thanks for suggestions.
Will see what I can do here closer to home first (home in Perth, Australia) then if need to look at shipping distributor to US, repair and back home which would be 3 or so weeks off the road.
With regards
Steven
