W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Mike K on June 10, 2015, 11:16:56
Title: Steering Box Rubber Seals- where to find?
Post by: Mike K on June 10, 2015, 11:16:56
I'm trying to source the 2 seals highlighted in the attached pic for the steering box, for a friend's car.  I have purchased the seal kit from SLS -
http://www.sls-hh-shop.de/en/230-280SL-W113/46-Steering/46-d-Steering-Gearbox-Fluid-Pump/Gasket-kit-pwr-steerg-div-108-113-Gasket-kit-pwr-steerg-div-108-113.html (http://www.sls-hh-shop.de/en/230-280SL-W113/46-Steering/46-d-Steering-Gearbox-Fluid-Pump/Gasket-kit-pwr-steerg-div-108-113-Gasket-kit-pwr-steerg-div-108-113.html)
but it does not contain these 2 seals.
Any help would be greatly appreciated.
Thanks and best,
Mike
Title: Re: Steering Box Rubber Seals- where to find?
Post by: tel76 on June 10, 2015, 11:45:37
Mike,
If you had purchased the overhaul kit from your local dealer you would not have this problem.
Have you reported the missing seals to SLS?
Post by: Mike K on June 10, 2015, 19:08:10
Thanks for your reply Eric. I will follow up with SLS,  I thought that they were not included in the kit.
Mike
