W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: Jack Jones on May 19, 2015, 02:20:42
I am looking for the caulk type sealant used on the windscreen trim and other areas. It looks like a type of butyl tape that does not set up like silicone.
Jack
http://www.crlaurence.com/crlapps/showline/offerpage.aspx?Productid=12500&GroupID=19963&History=30587:19747:19758:19951&ModelID=19963
What you are looking for is referred to as windshield re-sealant.
Thank-you Shvegel but this product cures and what I am looking for does not. It appears to be a mastic type of material and further investigation has proven to be a butyl product.
This is what I'm using for window sealing. Does not cure and its pretty easy to work with, as you
can use a chunk of the material to dab off excess material.
Info here, I assume its available from Würth in Canada as well.
http://www.wurth.co.uk/technical-chemicals/sealants-and-sealing-materials/bodywork-seals/glass-sealant-dab-off-310ml (http://www.wurth.co.uk/technical-chemicals/sealants-and-sealing-materials/bodywork-seals/glass-sealant-dab-off-310ml)
Hans
Here is another very universal alternative. I am going to use this for the windshield seal and other areas that require a thick, non-hardening, easy to apply caulk ribbon. Also works great for sealing screws that go through the firewall.
http://3mcollision.com/products/sound-deadening/3m-strip-calk-08578-black.html
I have used it for years and works great. Simple, cheap and no shelf life!
