W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: drawho on May 18, 2015, 17:53:00
Title: Unknown Parts
Post by: drawho on May 18, 2015, 17:53:00
Putting together a 1970 280SL that someone else took apart.
He was taking apart a 280SE at the same time.
Here is a photo of 10 parts.
Can someone or all of you be so kind as to tell me where they go.
Howard
Title: Re: Unknown Parts
Post by: CharlieSierra on May 18, 2015, 19:53:52
Number 4 could be the retaining pins for the brake pads (brake caliper)....
The rest looks like shrapnel to me..... Hopefully the experts may have some ideas.
Charles
Post by: georgem on May 18, 2015, 19:56:33
OK, I`ll start with the couple that look familiar:
7 - heater cable from the dash control to the fresh air flap.
8 - heater valve control lever (possibly)
2 - look like brackets to hold the radio in.
3 - could be the regulator off the previous owners b-b-q gas bottle;D
I hope I get at least one correct.
cheers
Post by: drawho on May 18, 2015, 20:20:08
Number 7 is a tube.
Number 3 --I have tow of these I bet they are off welding and cutting torch tanks.
Number 1 (left side is a dashpot damper rather stiff) Do not know where it goes.
I think the smaller pieces are to hard to see.
Let me try a close up
Post by: Peter van Es on May 18, 2015, 20:32:08
Dear drawho. I merged your two posts, and deleted the duplicate. Posting the same message in two different sections is called "cross-posting". That's a no-no in forum land.
Post by: drawho on May 18, 2015, 20:39:50
1.) is a very small shock absorber or dashpot
7) is a very small hole with fittings.
5) see close up attached
Post by: hkollan on May 18, 2015, 22:14:09
1 is an engine damper found on some w108/w111/"w112 cars, not for your pagoda
7 could be early style oil pressure line?
6 upper brackets for headlight chrome trim on w108/w111/w112 thus not for a pagoda
I believe 2 and 4 have been correctly identified
Hans
Post by: drawho on May 18, 2015, 23:04:39
Thanks everyone,
We have 5,8,9, and 10 left
5) the part sticking out is threaded
9) these look to attach with screw to hold the edge of something.
10) I found 9 of these-- see closeup of 8,9,10
Howard
Post by: badali on May 19, 2015, 16:26:50
5 looks like a clip that holds the end of the garnish trim on top of the doors
