W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: jackhughes81 on May 01, 2015, 05:31:10
Title: 65 230 sl water pump leak
Post by: jackhughes81 on May 01, 2015, 05:31:10
When I look at the tech manual, I can not find any pictures of the water pump or mention of its replacement.. help!!(http://[img])http://www.sl113.org/forums/index.php?action=dlattach;attach=28490;type=avatar[/img] This summer I intend to sell and would like to fix prior to listing.. :(
Title: Re: 65 230 sl water pump leak
Post by: pdc on May 01, 2015, 18:05:22
here you can find some information Jack
http://www.sls-hh-shop.de/en/230-280SL-W113/50-Cooling-System/50-a-Cooling-System-230SL/
best
P
Post by: jameshoward on May 01, 2015, 19:05:51
There is a wealth of information on the site about changing the pump. You should note that you have 3 options of pumps, but you would need to replace like with like. A search will dig up my post on changing the waterpump (pretty straight forward job, but you'll to remove the rad).  I think I ended up buying all 3 pumps before I realised all 3 were different.
