W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: rockingchairmotors on March 04, 2015, 01:10:00
I need some help with a head for a M130 engine. Head that came off the car is a 130 016 32 01 and is the cleaned one pictured.
I want to confirm that I can use this second head. # is 130 016 08 01. The dirty (black) picture. The chart posted in the tech info says it will work but once I took it off it looks totally different.
Will the second head work? Machine shop says it might be a different compression? Or a Euro vs. U.S. Head?
Before I spend the $$ at the machine shop I want to make sure it will work.
Thanks for the help
Those two heads are interchangeable. Also, they both have 9.5 to 1.0 compression.
