W113 Pagoda SL Group => Electrical and Instruments => Topic started by: Walter Marsh on February 17, 2015, 21:53:16
Hello Members,
This post applies to late model 1970-71 280SL's with Automatic Transmission, Air Conditioning, and Constant Speed Solenoids.
Trying to determine correct wire color(s) connected to the "Constant Speed Solenoid".
I have studied both wiring diagrams available on this site - Unfortunately, the only applicable diagram for my late model 280SL (US Version) is Black & White - Joachim Ahlert’s Color Diagram does not apply entirely to my vehicle.
So far, I've seen several 280SL's each with different wire color combinations.
(Image Below depicts Green/Red/Yellow/ and perhaps Solid Brown, Brown/White or Brown/Black it is unclear based on photograph)
What is the Color(s) of the wires connected to your Constant Speed Solenoid?
Walter
Hi Walter. My 1966 230 have green/orange and black,hope this helps.Mike.
On my early 250 SL, black with a green stripe and red spiral, green with a red spiral.
I take it your 280 SL has A/C. My 280 SL (12730) has the solenoid mounted but it is not connected, in these cars the constant speed solenoid is only used with the A/C.
