W113 Pagoda SL Group => General Discussion => Topic started by: n/a on September 16, 2004, 10:43:24
Title: Thermal Time Switch Location '70 automatic??
Post by: n/a on September 16, 2004, 10:43:24
Hi, trying to identify the time switch on my 1970 sl automatic.  Is it the small switch opposite the vaccum assisted switch next to the speed relays? Thanks!
Title: Re: Thermal Time Switch Location '70 automatic??
Post by: signalred280sl on September 16, 2004, 11:12:18
A thermal time switch is located on the driver side of the engine near the rear of the block about halfway down behind the injection pump. It is about an inch in diameter, largely made of brass, screws into the block, has a couple of wires connected to it and may have a rubber boot fitted to protect the terminals.
Les 1970 280SL
Post by: n/a on September 16, 2004, 14:14:55
Thanks, but are you confusing the the low temp sender with the TTS? This looks just like a water temp switch that screws into the block.  I will look again for the TTS which sounds like it is in the same vicinity as the low temp switch.  Thanks!
Post by: Benz Dr. on September 16, 2004, 16:26:08
No it's not.  That's the low temp switch for the ignition timing.
 The TTS is screwed directly into the back of the cylinder head. Earlier engine have this on the small housing attached to the cylinder head.
Daniel G Caron
Post by: signalred280sl on September 17, 2004, 05:49:30
James, I looked at mine last night (1970 280SL automatic). The temp. switch with one wire going to it is down lower and a little bit forward of the thermal temp switch with two wires which is located a couple inches below the bottom of the valve cover nearer the back of the block on the driver side. I'm a newcomer to all this so don't take my word for anything I say that you or anyone else determines to be incorrect!
Les
Post by: n/a on September 17, 2004, 11:52:26
Found it, now all I have to do is check it to see if it works.  How to test? I will see if there is a test procedure on this site, thanks!
