W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: gnj588d on November 28, 2014, 08:21:59
Is it possible to fit new rear motor mount without a vehicle lift,I only have
ramps.Looks like a difficult job working off your back. :-\.Cheers .Mike.
That depends on who's doing it!
In my early days I didn't have a ramp and could do a clutch on a 230SL in 45 minutes!
Yes.
Obviously easier with a pit or a lift, but it's not a bad job on your back. You need to raise both the front and rear ends, though. And you need a small jack to support the back of the engine while you remove the support plate and change the mount.
Thanks everyone,will tackle it soon.Cheers .Mike.
As a follow on question, is there a diagram which shows the correct assembly of the various washers/spacers etc that fit over the mount and the support plate. I couldn`t find it in the BBB or either of the manuals that I have and the SLS catalogue (normally a great help) isn`t clear.
cheers
Wow! That's impressive!
