W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: PMO956F on October 05, 2014, 09:01:54
Hi guys
Could anyone tell me which part this maybe , it was in the cad plating box with all the other bits (all mixed together!) still rebuilding the car so im sure i will find out sooner or later
clue - its not an engine or transmission internal
Any Help welcomed !
ps pic attached 7 years down the line !
It could be the rod that screws into the end of the clutch slave cylinder? Sure someone with better knowledge will chime in here.
thanks Andy , sorry should of mentioned its an auto !
Ah, what about the rod the screws into the firewall on the inside that the accelerator pedal stop on?
If you don't find what it is, ask the workshop who did the plating if someone complained he was missing a part. They often mix up stuff, and someone may be looking for it.
Is it metric?
thanks again , the floor was replaced so there is no bolt hole and my pre resto my photos dont show the area im afraid
BTw yes its metric , and yes i guess it could be someone elses missing part , but i had it all plated 3 years ago so cant check.
Thanks again for your help
Is it the cotter bolt off your rear diff ?
Does it have a taper on the other side ?
If you have replaced you floor you should have the hole that I am referring too. If you pin has that taper on the Dave is definitely nailed it.
It is definitely the rear diff pin.
Thanks Andy
Yes you may have it ! it doesnt have tapers , so could be the part , thanks for the pic its very usefull, and also to the other members for helping too!
This may be too much information, but for the true parts geek:
The PN for the accelerator stop is N 00084 0008220. An N number means that it is a generic part specified in the DIN und Normteile book. This number is in the book as a "cyl[inder] head screw" M8 x 50 mm, exactly as shown in the picture.
Good call, Andy.
Cheers,
CT
