W113 Pagoda SL Group => General Discussion => Topic started by: Ed Cave on September 01, 2004, 21:21:27
Someone recently suggested...
"Drive the car a bit first to see if you want a taller gear. The stock axle ratio gives 4600rpm at 80mph.. This can be changed to 3700 at 80 with a different axle."
Obviously this would make the car slower off the line but a lot more tolerable at higher speeds.
Can anyone elaborate on the cost / difficulty to achieve this and their satisfaction with a similar modification?
1964 356C
I put a 3.27 in my car. Makes a whole new automobile out of it: I cruise at about 3000 RPM on the freeway at 63MPH. I do not feel that the car is slower off the line, but it should be. If I really want to beat that Audi or Porsche, I start in first gear. My cost was $250 for the axle plus new bushings, maybe another 50 bucks. It's quite a bit of work and you have to be careful removing the compensator spring. But if I can do it, so can you. The attached picture shows the new axle ready to install
Download Attachment: (http://images/icon_paperclip.gif) RearAxle.JPG (http://www.sl113.org/forums/uploaded/theengineer/200491234843_RearAxle.JPG)
82.66 KB
1969 280SL,Signal Red, A/T, P/S, A/C, Both tops. Ret. engr. 1967 230SL - Sold
This car does not have a spedometer. But it has the original speedometer and it now reads 25% slow; i.e. 40MPH is really 50. On the funny side: 50MPH is 62.5MPH which is exactly 100Km/hr. So I made stickers to go on the glass in a few places, like at 30 (is 38) 50 and 60 (is 75). That takes care of our usual posted speed limits. Because of my extensive education I am also able - sometimes - to multiply the indicated speed by 1.25. It is especially easy when the speedometer indicates 100MPH
I put a 3.69 (was 4.08) in mine. The car was slower off the line, but now that my engine has been rebuilt, it's quite peppy again. Although the RPM's went down by around 10%, the difference is less noticeable than I had hoped for. Still an improvement I would recommend.
Being cheap :) Did you get the diff out of another Mercedes, scrap car or what???
Or are these diffs unique to the 230/280 range?
Malc
Oh BTW can you get limited slip differentials for a 230??
I've got the car completely apart right now, gauges out and everything. Does anyone know if the speedometer could be recalibrated (by a professional)to synchronize with a modified rear end?
If it can be done, now is the time! Also, it seems like half of the professional guage shops, repairers and restorers are in Van Nuys, CA. Anybody have a particular shop reccommendation?
North Hollywood Speedometer is terrific. I sent a speedometer there on a Monday and got it back as-new on a Thursday.
www.nhspeedometer.com
The differential I had put in came from a sedan car. And yes it was cheap: as I recall something like $400 including labor to put it in, and that took an entire day.
The tallest you will find in swing axle will be the 3:27.
Keep a look out for 108 chassis , 280SE 4.5 only ..
The 280SE , 6 banger does not use the 3:27... they figured the v8,3:27 match would be the best for a large sedan with the added power, but you can do the 113 cuz of the lighter weight , but it is more recommended for stick vs auto...
Opionions vary... I've had both ... if you do around town/back road driving , stay stock... but if you are a cruiser , the 3:27 makes it a new car on the highway...
I think it is an American thing....
If one does the math , the cruise of the 3:27 comes close to the RPM/MPH specs of the ZF 5 speed O.D in top gear.........
In another topic the effects of high gas prices (and more philosophical and social aspects) are being discussed.
I was wondering whether any of you know how the gear ratio affects the gasoline consumption (in mpg or ltr/100 km, I don't care which unit we use). In theory I'd say that a lower ratio (lower rpm at same speed) should improve gas mileage. But is that true in reality?
Perhaps Theengineer could tell us whether his gas mileage got better after the exchange. Ed, have you driven your car often enough to report your's? What gear ratio did you finally settle on?
Gas mileage / rear end question:
Probably depends on how and where you drive your car; city or highway. I did not change the rear end in my car and have not found driving at 70 - 75 mph to be annoying at all (as I thought it might be from some of what I had read).
1973 911S
2004 A4 3.0
2006 GS430
I did not notice a drop in fuel consumption after going from 4.08 to 3.69.
I went from a 4.08 to a 3.27 rear-end. Too many overall changes to isolate any gas mileage benefit from the 3.27. I can say that while cruising with the top down at 60 mph, I have to listen hard for the sound of the engine. Driving around town is not bad, and if you need the extra push, you can use the shifter (automatic).
Joe Alexander, Pete Lesler and I did some back of the envelope calculations at the Ohio tech session and determined that the 3.27 had a slight rpm advantage over the 5 speed ZF. That was after several libations, so maybe the calculations were off. :D
<<determined that the 3.27 had a slight rpm advantage over the 5 speed ZF.>>
The 3:27 would have quite the advantage on RPM.
A ZF520 in 5th gear with a diff ratio of 4:08 would equate to the same RPM as a 4 speed in top gear with a 3:46 ratio differental.
I must have a different back end to you lot already
I figure 50rpm per mph in top gear (280, Auto). It sits at
4000rpm/80mph or
3500rpm/70mph or
3000rpm/60mph
very happily.
Only having ever driven the one car, I have no basis for comparison
Mike Halleck ("Norton") is supposed to be putting a Mustang T5 transmission in his 113. It will be interesting to see if this has the intended result, and if it gives an improvement over the ZF and the effect of a shorter rear axle.
One thing I can tell you is that T5 transmissions should not be too hard to find.
Tosh,
I am at about 2800 rpm at 60 MPH. I don't hit 4000 RPM until over 90 MPH. I had my speedo recalibrated to the new rear-end and is very accurate. Sounds like you have a rear-end between the 4.08 and the 3.27 (I guess that would be the 3.46). I think Cees has a mid-range rear end in his 280sl.
"One thing I can tell you is that T5 transmissions should not be too hard to find" Right you are Mike, The T5's are falling out of tree's on my side of town. :D
Mike Halleck
Chesterfield Mi
71 280SL
68 250SL (parts car)
94 E320 Coupe
Mike Halleck
Chesterfield Mi
71 280SL
94 E320 Coupe
Well of course we are waiting to see your results. Don't work under a tree if they are falling out of them on the East Side.
Mike, if you can document what you learn with photos, you will have my undying gratitude. I have been looking at T-5s and there are a several different top shifters for them. One of the combinations should be right for our cars. A T-5 is my 2006 target project.
Will you be using the MB bell housing?
'68 280SL 4-spd Coupe
Most of the original 5-speeds were 230SL/250SL and were sold in the European market, so they would probably have the 3.75 rear end, bringing it's RPM levels closed to the 4-speed with 3.27 rear end.
A pack of Marlboros fell out of a tree on me when I lived off Washington Square North for five years. I remember it seeming not very out of place on that particular day. Gave them to the next free spirit I played chess with at the SW corner of the park.... Never got hit by a T5, just not that lucky.
-CD-
1967 230SL, 113.042 10
1983 300TDT, 123.193
5 speed Euro never came with a 3.75 differential.
A 3:27 w/4 speed would equate to the 5ZF with the 3:92 in top gear.
That is a common swap.
Dalton -- Re swapping to a 3:27 w/4-spd; can you please comment on the effect this has on acceleration? My question relates to Ed's observation, "obviously that would make it slower off the line".
I'm wondering if it really is much of an issue in terms of giving up some off-the-line performance. 1st gear has always felt a bit low to me anyway...so I have my doubts, but am not sure.
BTW, we are going to do something in this arena over the coming winter...Just not yet 100% certain what that will be. But, naturally, our objective will be to have it all. Meaning strong acceleration, good closeness, as well as comfortable, quiet cruising. We'll also do our best to take the HP & torque curves into account.
Thanks.
Tom in Boise
TR
Your chassis is a perfect candidate for the swap b/c you have a manual trans coupled with more HP/Torque than the .042/043 for low end.
You also already have the rear disc, so you do not have to worry about brake pressure mods.
Dalton -- Thank you kindly for the reply. Sounds encouraging. You don't think we'd give up much off-the-line acceleration then? Effectively a non-issue?
Tom in Boise
The up-side far outweights the down.
If one is looking for the cruise , it is a great mod.
I have seen many use the change with success and seldom , if any , do they go back to stock gearing.
I also pefer to see it done on manual trans chassis , where the driver has better control of load conditions. But that may also be my own personal taste of not liking 113s w/autos, regardless of gear ratios.....
Dalton -- Thanks. This will be part of our winter work.
Tom in Boise
Hello Tr,
The 3.27 seems to be the most popular gear. These units from Mercedes W108 3.5 and 4.5 V-8 sedans must be checked carefully. The pin that holds the spider gears in the differential wears it's mounting hole oblong in the yoke casting.
I find that about half of the used units I find are bad!
Attached is a picture of when I changed to a 3.27 axle. I have an automatic. I do about 3100 rpm at 62.5 MPH (100 km/hr). My last fill-up indicated about 22 MPG. Acceleration has never been a problem, but if you drive like that, you'll get less MPG's. This morning I accelerated away from a Lexus, up a steep hill. He wanted to race me. Left him in the dust. My file indicates that the picture was taken in Feb. '04. I have had the axle in for that long. I have no desire to go back. I didn't recalibrate the speedo. I can multiply the indicated speed and milage by 1.25 (on good days only) Officer - I was only doing 60!
Download Attachment: (http://images/icon_paperclip.gif) RearAxle.JPG (http://www.sl113.org/forums/uploaded/theengineer/2005917231728_RearAxle.JPG)
82.67 KB
Thanks Joe & Peter. We'll start getting into this, in some depth I expect, over the next several months.
Tom in Boise
I echo the suggestion that once you have a 3.27 rear-end in you car, you will not want to go back. Went cruising tonight up the GW Parkway in Washington-you know the road Tom, the same one we went along when you were here. Had the windows up and the windscreen on, but top down. It was very easy to conduct a conversation at 50 miles per hour in a normal, un-elevated voice. Of course the windscreen helps a lot, but the low revs from the 3.27 helps a bunch.
Does anybody have experience with the installation of a later 5 speed MB gearbox into a Pagoda? In this way the brisk acceleration would be maintained and the 5th gear would act as a welcomed overdrive on the highway. I used to drive MGA years ago and a popular modification was to fit a 5-speed Ford gearbox. It really did wonders for this little sportscar when driving on the highway.
Cheers
Finn
1964 MB 230 SL Euro 4-speed manual, silver metallic/black interior
Anyone have thoughts on the best source(s) for a 3.27 rear?
(I haven't yet posted a Wanted to Buy message).
Tom in Boise
Finn,
"Hauser" in this group has a very nice 280 SL with a later-style Getrag 5-spd installed, so he can comment on installing the side-mounted gearbox. I know he likes the unit very much as it shifts better than his earlier ZF 5-speed. There's been some talk about the gearbox on this site so I suggest you run a search on the word "Getrag."
