W113 Pagoda SL Group => General Discussion => Topic started by: n/a on August 25, 2004, 16:10:42
I just found out that my beloved '66 230sl has a small coolant leak. Coolant is leaking out of the engine and not into the oil. Will the coolant etch the block and make it worse to repair in the future. How much should this repair cost? Can I add something to the coolant to seal the leak?
Thanks for the advice
Hello Red,
Sorry for the bad news. I would first try re-torquing the head while engine is warm. Loosen the radiator cap before beginning to relieve pressure. Loosen a head bolt one full turn then re-torque to specs (I would take it up to 70 ft. lbs instead of the lower specs. under these circumstances). Do this one head bolt at a time in reverse tightening sequence.
Adding sealers to the coolant is normally not a good idea. The sealer will travel to all parts of the cooling system and may clog up other things.
Cost depends on the labor rates and experience of your mechanic. The big problem is figuring where to stop. You may have to decide on whether to re-condition the head or possibly more before replacing the head gasket. At the very least consider replacing the timing chain if it has close to 100,000 miles on it. Good luck, keep us up to date.
