W113 Pagoda SL Group => General Discussion => Topic started by: Ph2ocraft on April 04, 2014, 15:48:16
Title: Valve Stem Seal Kit
Post by: Ph2ocraft on April 04, 2014, 15:48:16
Where are you guys/gals purchasing your valve stem seal kits?
I didn't have luck locally :(
127 586 01 05, Valve Stem Seal Kit
Title: Re: Valve Stem Seal Kit
Post by: Jack Jones on April 05, 2014, 02:54:22
Call Mercedes!
Post by: Ph2ocraft on April 05, 2014, 04:31:57
That's what I did.
I just hate paying over 100 bucks for something that costs less than 23 bucks.
Post by: 66andBlue on January 17, 2015, 05:39:12
What 23 bucks?? Way too much, how about $15!!
http://www.ebay.com/itm/351236466265
Post by: Benz Dr. on January 17, 2015, 06:27:22
230SL valve seals are always more than 280 or 250 seals. Make sure you install the seal dry or it will pop off.
Post by: Shvegel on January 18, 2015, 17:14:37
I would see if anyone makes seals out of some "Rubber" material rather than the teflon or plastic of the ebay seals.  They will tolerate a lot more in terms of loose valves etc.  Not sure if the 230's do it but the M130 2.8 engine has a tendency to have the valve guide to slip in the head casting so rather than the valve riding in the valve guide the guide moves up and down in the head along with the guide.  I replaced my seals before Joe Alexander pointed me to the real problem.
