W113 Pagoda SL Group => Electrical and Instruments => Topic started by: Rolf-Dieter ✝︎ on December 31, 2013, 00:29:20
Title: Some electrical issues ... has this happened to you?
Post by: Rolf-Dieter ✝︎ on December 31, 2013, 00:29:20
While taking my Pagoda out for a spin this afternoon I noted that both my left and right indicator did not work also the high and low beams ... naturally I kept my drive short.
Could it be a simple fuse issue or something more critical that you may have experienced. Temperature was -3 C (27 F) not cold at all, did something shrink in the cold?
No problem if no one came across the same issue, I'll find the fault eventually. Just sought I'll check with you here.
Thanks in Advance.
Title: Re: Some electrical issues ... has this happened to you?
Post by: Larry & Norma on December 31, 2013, 09:24:28
The problems you describe all have connections through the indicator stalk
so I would check the connector on this has not come adrift.
Post by: Rolf-Dieter ✝︎ on December 31, 2013, 15:14:11
Thanks Larry, will do .... Best Wishes for a Happy and Healthy New Year!
