W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Rok on November 25, 2013, 22:27:50
Title: 1971 280sl automatic trans
Post by: Rok on November 25, 2013, 22:27:50
hello
can anyone tell me where i can find an accurate parts illustrated publication that  shows a picture of an area along with a part # for example, i need currently the automatic transmission bushing(s) (if there is more then one) that connect the linkage to the shift lever, mine is disintegrated and fell off.
also before this happened, the car would start in any gear .... was accidentally started and took off in reverse, fortunately i stopped it in time but wow what a scare... any thoughts???
thx
rok
Title: Re: 1971 280sl automatic trans
Post by: Valvechatter on November 26, 2013, 00:23:45
Hi there,
Just been there and done that. See this thread: http://www.sl113.org/forums/index.php?topic=19453.0
Just give Tom a call at the classic center and he will fix you up. The postage was slightly more than the two bushings which were under ten dollars.
Lin
Post by: ja17 on November 26, 2013, 04:12:06
Hello Rok,
The neutral safety switch is mounted on the firewall. It keeps the engine from starting in forward or  reverse gears. It is controlled by a cable which goes down to the transmission linkage lever. Make sure it is not broken or bent. Replace the linkage rod bushings first then adjust the cable so the car only starts in neutral or park. New cables are available for less than $30.00 if yours is broke.
Post by: ctaylor738 on November 26, 2013, 14:13:15
Suggest you sign up for a free subscription to the Mercedes Electronic Parts Catalog (EPC) at www.startekinfo.com to see diagrams and part numbers.
Post by: Valvechatter on November 26, 2013, 22:04:13
ROK,
The part number is: 112-268-01-50. I just ordered two last month from Tom Hanson at the MB Classic Center 949-598-4845. $3.57 per bushing. You need two for both ends of the link, though you probably only have one that has failed.
Lin
Post by: Rok on November 27, 2013, 00:47:52
hello ...went to the mercedes parts catalog site but it indicated a subscription in 1 week to 1 year increments and costing up to 3000.00 dollars for access? am i looking at the wrong place .. thank you for the help.
rok
Post by: ctaylor738 on November 28, 2013, 19:50:17
Sorry, the URL I gave you was wrong.  Try here:  https://epc.startekinfo.com/epc/home.jsp
Post by: Rok on December 03, 2013, 11:46:35
hello ctaylor 738 or anyone else using the MB Tech info site...
was finally able to get the site link to work.... i think the shopping on the internet created such heavy traffic it would not work.. one question please, the site (when subscribing) said it is free yet they want a credit card w/no explanation in order to continue...  do you know if there is a charge and/or why they want a credit card..?
making progress with the car slow but certain.. thank you everyone for the continued tips and info :)
thx
rok
Post by: ctaylor738 on December 03, 2013, 12:00:10
The EPC is free only for US residents and they use the card to verify your address.
