W113 Pagoda SL Group => Electrical and Instruments => Topic started by: schadiqi on October 12, 2013, 16:15:43
I thought I had solved my problem and have ordered 6 new spark plug wire. I had noticed when the engine is warm I get no spark on 2 cylinders and the engine responds with power loss ( then runs only on 5 cylinders) When everything cools down again I get the spark back on the 2 cylinders again . When cold, the engine runs perfectly.
Today I added 6 new spark plug wire and I have the same problem with the 2 cylinder ( No spark when engine is hot) Well I do not understand the world anymore ?
The following new Mercedes Benz parts I have installed so far :
ignition Coil
capacitor
distributor Cap
Rotor
New cable from ignition coil to the distribution center
6 new ignition
Why always the 2 cylinders ? Other cylinders are ok!
Does this have anything to do with the ignition timing ? or distributor
For any help I am very grateful . I do not know where to look further
regards
Dirk
Sounds like you have distributor trouble. Have you taken a close look at the lobes and checked the bearings for play?
(Although you don't list it, I'm assuming you checked the plugs themselves).
Dirk, check your messages I send you a PM hope it helps.
Thanks for your feedback. All 6 plugs are new as well. How to checked the bearings for play? The distributor sits very tight ..no play. I may have to remove it and take a close look . Why always the 2 cylinders ? Other cylinders are ok
Thanks a lot
Dirk
If the two cylinders are side by side you may have head gasket problems. I would do a compression test on all cylinders to compare each one to the others.
Anything lower than 90 - 100 PSI and you probably won't get the cylinder to fire.
Hello
The compression test on all cylinders are very good . (New Engine with 8000 km!) I just do not see (visual) the spark (Test: pull out the cable with plug and insert other plug and put on ground when Motor running) when engine gets at operating temp no spark. So it must come from Distributor? , because all other cylinders are ok! Where is the fault. When everything cools down again I get the spark back on the 2 cylinders again . When cold, the engine runs perfectly.
Thank you
Dirk
Have you checked your valve lash? Do you have compression on a hot engine?
This looks to be a mistery issue that takes a lot of head scratching to solve. I've had a few of them I will describe below. None of them correspond directly to your symptoms, but it may give you some ideas.
I had a similar issue on a W109 6.3 where I was loosing spark to four cylinders when the engine was hot. Eventually spark would disappear on all cylinders. The culprit was a wire connection to one of the two sets of points. When the engine was hot metal was expanding and the connection was too close to the distributor flange and was ending up touching it. As a result that set of points was grounded leading to the loss of 4 cylinders. After a while it was grounding the whole system and the engine was stopping. In your case we could imagine a similar thing happens but only at a certain position of the shaft relative to the flange (in case you have a bit of wobble in there) leading to the loss of the two cylinders corresponding to the lobes on the shaft in a given position.
Another issue that took a lot of head scratching was the wire that goes through the distributor (or the connection you have there) is damaged and you also have some grounding happening there. But you would be loosing spark on all cyliders.
More recently, I had two HT wires crossfiring because they were next to each other while spark was on two consecutive cylinders. Spark was jumping from one to the other wire leading to misfiring. This happened on an EDIS ignition which is much more powerful than the one you have, but you may try to run the wires as distant as possible from each other and see if your problem is still there.
The spark will start jumping out of the wires when the resistance becomes too high.
Make sure you have non carbon type spark plug wires first of all. Non resistor spark plugs will also help. Next take an ohm meter and check each spark plug wire from distributor through the spark plug connector. The resistor wire ends at the spark plugs go bad. When this happens the spark finds the least path of resistance and escapes to ground (earth) any where it can.
Today as we had good weather in Bavaria we took the car for a ride again. When Engine is warm and it went off again to 5 Zylinder .. There is no spark on the cylinder 2. I then gently touched the distributor cap when the engine is running. Minimum rotation with a small force in the right direction and he ran again on all 6 Zylinder . I have minimal play on the distributor cap despite fixed braces. Is this normal? Or shaft wear? Or incorrect ignition timing?
But slowly we are getting closer
Thanks for all tips and best wishes
Dirk
Normally, there is some sort of insulating plate in between the distributor and the cap. I've seen many cars running OK without it. However I've also read an article about how ignition could malfunction with that part damaged, see here: http://www.w124performance.com/docs/mb/other/ignition_misfiring_STAR.pdf
You could also try to turn the distributor cap by 180 degrees and see if the problem is still there, and if so on which cylinder.
I don`t think you can turn the cap 180 degrees because it`s designed to only fit in one place.
Oooops! That's true!
Thanks for all reply
After I put in a rebuilt distributor (0231 116 062) all my problems are gone
Dirk
Shall I send you a bill? ;D ;D ;D ;D ;D
