W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Pedrocamp on October 10, 2013, 16:42:01
Title: Heat Exchanger repair
Post by: Pedrocamp on October 10, 2013, 16:42:01
I am repairing an oil water heat exchanger as was covered in this 2009 thread by waqas:
http://www.sl113.org/forums/index.php?topic=11013.25
If anyone has performed this repair could you recommend a solder and flux to use and any tips in securing the brackets to the unit without ruining the perimeter seal? This wasn't mentioned in the thread, a radiator shop did it for waqas. I have the unit stripped down... brackets off, the halves apart and bead blasted clean, see attached. I'd like to make sure I get a good solder bond and seal the first time.
Pedro in Mooresville ,NC
