W113 Pagoda SL Group => General Discussion => Topic started by: erickmarciano on July 25, 2004, 20:37:13
when cold it sucks very loud and as the engine gets hot the noise goes away but when I block the air valve when hot the suction build up after about 2 seconds is it normal<I feel a litle vacum not much >? . just replace the air valve thermostat on my 280sl and the base if the thermostat was larger I had to make the hole biger in the plate where it sits.
thanks
Erick
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
Hello Erick,
I recently replaced my fuel injector pump thermostat on my 1970 280SL. Had the same issue as you regarding the plate the thrmostats sits on. So like you I enlarged the hole so the thermostat fit snugly. When hot the thermostat arm extends and pushes a cylindrical air valve which blocks air from coming in through the fuel injector pump air filter. As I recall there are no o-rings or other sealing devices on the air valve. I think this will create the potential for a very slight vacumm, especially as the air slide valve wears over time. Given the lack of a more robust seal I think a very slight vacumm when warm is probably okay. I'd be interested to hear what others say.
Hello Eric,
I agree with you Jeff. A bit of vacumm leak will make very littl difference.
