W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: relbhcb on June 08, 2013, 19:02:45
Does anyone know what the torque setting is for the single large nut that holds the steering wheel on to an early 230SL? Or where I would find it?
I had to remove my steering wheel to fit a new multi function "stalk" and would like to know how tight I need to do the wheel up again.
Many thanks!
Julian
PS I did search, but couldn't find anything ...
Does anyone know what the torque setting is for the single large nut that holds the steering wheel on to an early 230SL...
The M-B Book of Tables states it to be 80Nm
/Hans in Sweden
Hans - many thanks!
The M-B Book of Tables states it to be 80Nm. You may want to use some light locking compound (like Loctite) to be extra sure.
/Hans in Sweden
There should be a lock under the nut to keep it from working loose. I won't use lock tight on anything I want to take apart some day. If anything, I use anti sieze more often than anything else.
Because the steering wheel is kind of hard to hold on to while tightening this nut, I use my impact gun to make sure it's tight. Put it on a low setting.
