W113 Pagoda SL Group => Electrical and Instruments => Topic started by: gvillayandre on April 06, 2013, 08:01:04
Title: Solenoid Test
Post by: gvillayandre on April 06, 2013, 08:01:04
Hi all,
I am not sure if my double acting solenoid on the auto transmission is failing.
Can I test it applying battery power to it?
Ground to brown cables
Power to black to test kickdown first.
Power to white to test venturi switch.
Thank you for your support!!!
Title: Re: Solenoid Test
Post by: w113dude on April 06, 2013, 12:11:35
Yes, you can test it this way, brown ground, the other two wires should move it either direction.
Post by: gvillayandre on April 06, 2013, 13:16:02
Thank you!!!
