W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: MBSwede on April 05, 2013, 17:19:16
Title: The ‘painfully’ stupid oil FI level check on 250’s … a poss solution..? >:(
Post by: MBSwede on April 05, 2013, 17:19:16
Hi all,
Are just in the process of re-commissioning my 250 -66.
One of the most irritating and inaccessible tasks on the checking the FI oil level on the 250.
No wonder MB changed the design for the 280 to eliminate the aggravating searching and fumbling with the dip-stick on these.
Both draining and checking the level is near impossible.
NOW, I know that later MB Diesels with similar pumps have 1. a drain plug and 2. a overflow plug eliminating the need for the dipstick.
MY question: have anyone tried to fit the equivalent to ‘our’ pumps ? … would make life a looooot easier. Drain and fill to right level in minutes
It should surely be possible to fit both drain and level plug in the back lid..?  … I would if I had the pump out ....   anyone tried??
Cheers
Fred
Title: Re: The ‘painfully’ stupid oil FI level check on 250’s … a poss solution..? >:(
Post by: enochbell on April 06, 2013, 18:52:21
Fred,
It's really not that bad if you have a couple of special tools.  I use an oil extractor (mine is Mytivac, but there are others) and vacuum the oil out through the fill hole.  Then I use a 6" piece of the same tubing used for the extraction and stick in on the end of a turkey baster (do NOT tell my wife!) and careful pour fresh oil in the open end of the baster.  You should get a baster that has measurement hash marks.
I have not seen a capacity figure anywhere, but my early 230sl takes 2 1/4 ounces of oil.
Hope that helps.
Greg
Post by: jameshoward on April 06, 2013, 20:59:21
I use the trigger assembly from a bottle of Mr Sheen and get the oil out that way. (I'm cheap).
I think its about 170ml isn't it? The dip stick is a bore, but probably the lesser of two weevils compared to modding the pump. That's expensive. (from personal experience).
JH
Post by: paults1 on April 06, 2013, 21:10:01
The max oil capacity per the BBB is 250ml. I also use the mityvac to remove & too pump in the new oil via the filler hole. The safe range is between 150ml to max 250ml. I put in 230ml.
Post by: enochbell on April 06, 2013, 22:35:28
OK, now we are really in the weeds.  To check the oil level should the dipstick be screwed in to it's seat or should it be checked from the top of the threads position?  Thanks,
Greg
Post by: MBSwede on April 12, 2013, 18:25:10
Hi , the dipstick should be screwed all the way down ... and doing that without loosing skin on all my knuckles are practically impossible
,, not least one have to do it 3 times each time the oil is supposed to be checked / topped up /replaced .. which should be done at least every year
+ the exact level of the new oil is pretty hard to spot on the dipstick after a few attempt have smeared oil all over the opening …
MB obviously realized this thus modified the system on the 280...  :(
My idea came partly from a old Swedish manual were they recommend simply to loosen the M6 screws holding the rear lid and drain the pump that way…
+ Diesel guys talking about how the check the level in newer MB’s
If I had a spare lid I would think it would be worth a try …
Post by: Paul & Dolly on June 07, 2013, 14:01:15
You can easily check the level by making a temporary  dipstick from a cable tie, the oil clings to the grooves and is easily seen.
The dipstick length is approx. 6 cm, and the level mark is about 1.5 cm from the bottom.
Paul
Post by: 66andBlue on June 07, 2013, 22:00:29
Thanks Paul!
Quite a convenient tool.
