W113 Pagoda SL Group => General Discussion => Topic started by: seattle_Jerry on March 30, 2013, 08:54:01
Saw this driving down the freeway on a hauler...followed it to the yard
They will sell me the whole thing for $800...not sure I want the hassle of parting it out
This is the euro model. You should definitely get the headlights. They will sell for a very good price.
The 250 engine is not that common, so if someone needs one, this may be the opportunity.
If the car has a manual trans, you could get the trans, shifter mechanism, pedal assembly, flywheel etc. as a conversion kit from auto to manual.
You could get the front kingpin assemblies if they have no play as this may save some work and money to someone who needs overhauling them.
If it's not too rusty, someone save this car !! ;D
Lots of good parts to pick on this "sedan of the era". W113 parts galore! The valuable horns, engine including the cylinder head, injection pump, power steering pump cold start valve, sensors, relays, steering box, automatic trans, hub caps beauty rings, very expensive exhaust manifolds, steel wheels, brake and suspension parts, interior switches, radio, expensive steering wheel, alternator, starter,AC compressor, NA interior window cranks, and more. And yes those sedan euro headlights are worth a pretty penny. They fit the W109, W108,W111 sedans and also the W111 and W112 coupes and cabs of the era.
Also, would have the complete pagoda-compatable rear diff. Possibly a 3.69
I did buy a 250 while back, If you have the time and space do it, Is it worth it? I'm not sure but I'd do it. just make sure the you and your wife are on the same page, otherwise it'll come to bite you later ;)
I'm single ;)
Yes there is rust and while the interior was perfect someone left it get wet. I'd bet the frame rails are rusty. The rear door corners are as are the wheel wells and dog legs
Good enough that I picked up two cars last summer. 280SE and a 2350SE - not running but complete cars.
I'm not going to get it...if it had been a stick I would have.
