W113 Pagoda SL Group => Electrical and Instruments => Topic started by: jedwards on March 29, 2013, 10:01:33
Hi, I have an early 250SL and I am hoping someone might be able to help me with a picture of the wiring onto the board of the column switch?
Mine seems to have been "fixed" by someone previously and wires are very poorly soldered. When I test the switches outputs at the male connector end, I have no switching at the pins for headlight flasher, windscreen washer and I only have 1 speed only wipers. Turn indicators are OK.
I suspect that the wrong wires may be soldered onto the wrong terminals points, but without an image, I cannot se where are supposed to connect.
Can anyone help?
Technical manual under 'steering column switch' shows some info.
