W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: natenate on February 12, 2013, 08:58:07
Title: Fouled spark plugs problem
Post by: natenate on February 12, 2013, 08:58:07
1967 230sl
Hi
The spark plugs are getting fouled (black carbon) very quickly seems that I have a fuel problem. Not sure what my first step should be with addressing the problem. Any advise would be a great help.
Title: Re: Fouled spark plugs problem
Post by: w113dude on February 12, 2013, 12:45:27
I would make sure the linkage on the top is correct to stat with, this will make sure your air/fuel ratio is correct put new plugs in and try, it could also be weak coil, bad wires or plugs.
Post by: Richard116e on February 12, 2013, 13:04:09
Hi
It could be just that you just need to take the car on a long run.  Starting up for short period of times  for example in the garage over winter can foul up the plugs.  This could be a starting point to looking at the problem.
Thanks Richard
Post by: ja17 on February 12, 2013, 23:41:36
The "WRD" is another item to check early in the quest.  If it is stuck, you can have a very rich running condition. Give us some history and ask more questions.
