W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: ctaylor738 on January 26, 2013, 17:38:20
Title: Pinion Seal Replacement - holding the pinion shaft
Post by: ctaylor738 on January 26, 2013, 17:38:20
I replaced the pinion seal in my 280 project yesterday.  Not having the holding spanner 111 589 02 07 00, I came up with this arrangement to keep the pinion from turning while I loosened and tightenend the slotted nut.  It's a 10 mm bolt with three nuts.  Two secure the bolt to the flange and the third butts up against one of the bolt heads on the cover.  To tighten, I just moved the flange so that the third nut was against the bolt head below (obscured by brake cable).
Title: Re: Pinion Seal Replacement - holding the pinion shaft
Post by: w113dude on January 26, 2013, 17:50:23
It's genius Chuck! this would have come very handy last week.
