W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: friendofaustria on January 08, 2013, 18:44:11
Hi everyone,
can someone please give me a guideline how to remove passanger side bracket (can be pivoted, has brass ball) of the cross over linkage. I need to get this off to be able to remove the all the removable parts for "yellow zink" job.
I have attached a pic.
thx
Gerhard
66 230sl
There's a roll pin that you will need to remove first before you can remove the lever on the pump end of the shaft. The bracket with its bearing will slide off the shaft after that.
thank you, but I'm looking for the bracket on the opposite side to remove as marked on my picture.
thx
Gerhard
As you can see, I don't always look at the pictures. :-[
The shaft should simply pop out of the bracket. There's a heim type bushing on the shaft that's held in place with an E clip. When you're ready to install, just give it a good push and the bushing will pop back into place.
thanks a lot. I will try tomorrow
thx
Gerhard
