W113 Pagoda SL Group => Electrical and Instruments => Topic started by: natenate on December 07, 2012, 15:34:16
Title: timing issue
Post by: natenate on December 07, 2012, 15:34:16
Hi
I have a 1967 230SL manual, I am having some serous timing issues. The car it running very bad. Does anyone know what the timing set up should be? It’s a bosh 0231185009  JFU6 distributor .
Thank you
Title: Re: timing issue
Post by: Garry on December 07, 2012, 22:00:24
Nate,
You probably need to run through the Linkage Tour, however as a non full member you will not be able to access that part of the Fourm.
$30pa is all it takes to join and have ful access with access to Pagoda Notes and to recieve the world famous Pagoda World as well.
Trying to drum op business but not pushing or anything :P :P ;)
Membership Secretary
