W113 Pagoda SL Group => General Discussion => Topic started by: SL113fan on June 24, 2004, 05:25:40
Title: "280SE" engine marking
Post by: SL113fan on June 24, 2004, 05:25:40
What's the meaning of having "280SEL" embossed on the left side of a 113's cylinder head?  I read somewhere that the factory would sometimes use the SE engine in the SL because of supply issues.  Does an "SE" engine make a 113 less desireable, assuming that it's the original engine?
Title: Re: "280SE" engine marking
Post by: ja17 on June 24, 2004, 10:27:33
The cylinder heads were shared between SL's and sedans except fopr the 230-SL's which were unique. You are looking at the cylinder head.
The thing that differentiated which engines were originally in sedans or SL's was the engine number on the cylinder block below the head.
Post by: Benz Dr. on June 24, 2004, 11:41:55
Somewhere around mid 1969 the factory came out with a new engine. This one has the 280SE/A on the cylinder head. Nothing is the same between this head and the earlier 280 head - even the block is different.
 Only way to tell if you have the right engine is by engine number. It's not that big of a deal though - no one is paying more for numbers matching cars.
Daniel G Caron
Post by: n/a on July 17, 2004, 12:07:48
Hi All, my 280sl has the marking 180se/sl also on the lefthand side
it also has aircon in working order engine is like new sounds great
can we tell what year the engine was made from the numbers? or
what extras they had like emission control or aircon like mine?
 Thanks Pagoda Red
red kelly
Post by: hauser on July 17, 2004, 12:16:15
We all try to read up as much as possible on our cars and try to be informed on different aspects. I remember reading something on the www.oursl.com site that these engines were prone to overheating. Mercedes would replace them from those designated for a sedan because they were cheaper. Is this correct?
Post by: Cees Klumper on July 31, 2004, 01:14:24
What I know about factory replacement engines is that they did not carry an engine number from the factory, this was left to the installing dealer to stamp in - this way they could insert the original engine number. So in effect this means that there could be two engines with the exact same engine number around, if the original one was later rebuilt. I have been picking up used engines for future rebuilding (I know, my hobby has gotten out of hand) and I now have three engines that don't have a number. Replacement blocks typically carry a little metal plate just below the flat machined surface where the engine number should be, that states that it is a "Tauschgerat" ("exchange engine" - sometimes this plate is in English).
There really is no difference at all between the basic sedan and the SL engines. For an SL, you need the tachometer drive (the sedan engines did not have the necessary gear set but this can be bought new and added, or just changed over from your old SL engine into the sedan engine). Then the camshaft may be different (can be swapped or bought new, although the 10 or so extra HP only come in at very high revs, where most of us never care to go) and the injection pump (just swap). Then finally the engine numbers are different, but that's really only cosmetics.
So I don't think there is any truth to the story that MB would prefer to put in sedan engines into SL's to reduce the likelihood of overheating: the engines are essentially identical. What is a fact, then, is that MB would supply the same replacement engine whether you had a sedan or a Pagoda: then it was up to the installing dealer to make the few modifications noted.
There may come a time when original engine number becomes important to collectors, however if you look at any advertisement for a W113, 'original numbers' is never mentioned. If it were to become important, it is apparently very easy to change an engine number (so I have been told!) so long as you have a grinder and a die punch set (any old hardware store). From the engine number, one should be able to tell the year it was built I suppose.
Sleeping sedan engines can still be found today in barns, garages and abandoned cars, at a reasonable price.
