W113 Pagoda SL Group => General Discussion => Topic started by: Cees Klumper on June 10, 2004, 23:22:01
Title: Turbo Pagoda - really!
Post by: Cees Klumper on June 10, 2004, 23:22:01
Arnold Popky has listed his car in the registry with a 5spd and turbo engine:
http://www.sl113.org/data/carreg/show_table.asp
Title: Re: Turbo Pagoda - really!
Post by: Albert-230SL on June 11, 2004, 03:35:04
[:0]... So the rear badge of this Pagoda should be "240 SL TD" or "240 SL Turbo Diesel"  ;)
Albert de la Torre Chavalera
Barcelona (Catalunya/Spain)
Post by: mdsalemi on June 11, 2004, 08:42:57
Hasn't Walter Klatt been working on one of these?
Post by: Cees Klumper on June 11, 2004, 08:45:35
Michael - Walter reported working on a diesel SL but to my knowledge this project has not yet been completed. Also I don't think this was a turbodiesel. I owned a white 1982 W123 300D turbodiesel for a while, living in Florida. It was one of the most pleasant cars I ever owned.
Post by: Shvegel on June 12, 2004, 04:35:15
I had thought about adding a turbocharger to my car and went as far as to buy a spare engine so I could sacrifice that to the cause as opposed to the original. After some thought I realized that besides the fact that the engine is already 9.5 to 1 compression and the exhuust plumbing whould be a chore there is still the issue of having to change over the fuel system in order to allow for boost enrichment. I guess you could pipe a small tube over to the atmospheric diaphragm on the injection pump but that still would not be precise enough to keep from toasting a piston or two.
 The end result is I like it just fine the way it is.
