W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Paul99 on March 13, 2012, 18:10:07
I notice that my real wheels seem to have a slight negative camber, that is the bottom of each wheel is closer to the center of the car than the top. Similar to the old triumph heralds (if anyone remembers those!)
Its only slight, but don't think its correct. How do you adjust this? Is it correct? Should there be negative camber on the rear wheels?
Sorry if this has been discussed before - but i cant find it anywhere.
You are describing positive camber which is correct.
See here:
http://www.sl113.org/forums/index.php?topic=16081.0
