W113 Pagoda SL Group => General Discussion => Topic started by: erickmarciano on June 07, 2004, 18:49:36
should any of the dash lights work when the doors are opened?<one of the 3 lights on the center cluster?
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
The center red light will come on when the doors are opened. This light also functions as the indicator light when there is a malfunction in the brake system.
From the 280 sl Owner’s Manual:
"Brake control light (in instrument cluster, underneath the generator indicator light). The control light will show red if the brake fluid in the reservoir is at the minimum mark (see a MB dealer immediately).
You may check the functioning to the control light by opening one of the doors; the light must show red."
Per G. Birkeland
69 280 sl aut 834
Norway
I get a yellow light in my instrument cluster when I open the door of my early 67 Euro 250SL. Sounds different from everyone else.
Tom,
Does your 250 have a 'brake fluid low' indicator switch on top of the brake fluid resevoir?
Naj, my car doesn't have a low brake fluid indicator. It has all the early SL details vs. the later modifications, (#002650).
Hi, Tom,
This yellow light was in the cluster in the 230sls as well but not used. It was used for a different purpose in some sedans - there was a thread as I recall.
Some PO may have wired yours to indicate 'open door'.
On my 230, I used it to warn of low oil pressure. I was able to change it to red with a plastic 'window' from another spare cluster.
Naj, that is interesting. In my original 250SL owner's manual, the instrument cluster description does not show the center (yellow) indicator to have a function. I think I'll keep it wired the way it is for the obvious benefit, and besides, I don't feel like tearing apart the dash again!
